Installing Creo3.0 on to student machine
bchauhan
6-Contributor
Hi Guys.
Good evening.. i need your help.. well basically, teacher want to me to install Creo 3.0 from MED-100WIN-CD-400_M190_Win64 onto all student machines.
Now i have read all the instruction on how to install Creo 3.0, when it comes to section where i have Run - setup-schools.exe and i have right click the file and select " Run as Administrator" - Successfully done
then i click install new software then click Next - Successfully
then i accept the licence agreement then click Next - Successfully
then i cannot see any list of Creo programs in the box as its all white box.
What can i do to get to see list of Creo Programs which i can install or not etc.
Please advice me please.
Look forward to hear from you soon.. Thank you
Kind Regards
Bhav
Hi Martin,
I've sent him 40 individual codes, so he will use one for each computer.
It seems that the K12 product code works for multiple installs only if you create an teacher account.
Alex
6 REPLIES 6
@bchauhan wrote:
Hi Guys.
Kind Regards
Bhav
  • unzip MED-100WIN-CD-400_M190_Win64.zip
  • run setup.exe
  • use BK400407EDSTUDENTUNICL (university student) or BE400407EDSTUDENTEDK12 (K12 student) as Product code
Martin Hanák
bchauhan
6-Contributor
(To:MartinHanak)
Hi Martin
Thanks for Licence for K-12, as i try to enter the key and its gives me error message
i have tried to run as Administrator, still given me error message.
Please advice what next step shall i do ..
Kind regards
Bhav
@bchauhan wrote:
Hi Martin
Kind regards
Bhav
as you can see in https://community.ptc.com/t5/PTC-Academic-Program-Discussions/Start-up-license/td-p/237246 discussion, product codes worked well in 2017. Unfortunately I do not know why they do not work today.
Possible cause no. 1.]
Installer cannot find suitable network card. Please run ipconfig /all > ip.txt command in Command Prompt window and upload ip.txt.
Possible cause no. 2.]
Product code BE400407EDSTUDENTEDK12 does not work anymore. You can install Creo 7.0 to get license file and then install Creo 3.0 using this license file.
Creo 7.0 Student edition: BK700908EDSTUDENTEDUNI
Creo 7.0 Schools edition: BE700908EDSTUDENTEDK12
Martin Hanák
bchauhan
6-Contributor
(To:MartinHanak)
Hi Martin
Please find an attachment when i move the mouse to Error message it stated
" You have reached the maximum number of license requests available for your product type"
What the next step shall i do ?
Kind regards
Bhav
@bchauhan wrote:
Hi Martin
Kind regards
Bhav
1.]
2.]
Check your mailbox ... look for messages containing Creo 3.0 license file (as attachment).
Martin Hanák
Hi Martin,
Alex
