Is there a way to use a file from Autodesk Inventor on Ptc Creo?
tbatchelder
I have some models and parts that I made in Autodesk but we want to start using Creo. Is there a way to convert an Autodesk model over to Creo? Thanks!
sm
(To:tbatchelder)
If you cannot open the Autodesk Inventor files directly in Creo 3.0, try exporting STEP from Autodesk and importing the STEP in Creo.
sm
(To:tbatchelder)
