Is toolkit included in University Version?
Askarke
9-Granite
I was trying to install Creo Parametric Toolkitt following Getting Started Guide, but I get stucked. When I reach step 2.8( Running the Makefile Project), I can´t proceed to the next steps. I built make_install and modified protk_install_example/make_install/creotk.dat, but I can´t use auxiliary applications at Creo Parametric. You could check the steps I followed (until 3), and how is Auxiliary Applications locked.
1 ACCEPTED SOLUTION
Toolkit module is not included in free Student license.
Maybe @Alex_Cazacu knows what license you need.
Martin Hanák
5 REPLIES 5
Martin Hanák
Indeed Toolkit is not included in Education licenses:
https://apps.ptc.com/schools/references/Creo9_Education_Editions_Comparation_Chart.pdf
~Alex
Is there any option that i could change/play with the API? Like using VP Api, or is it blocked too.?
I was trying to use VB Api, but I´m unable to use it.
I would like to know, because I need it to my Thesis
you ca use VB API and J-Link.
VB API ... ask Google ... creo how to use vb api
J-Link ... ask Google ... creo how to use J-Link api
Martin Hanák
Thanks!
