I'm experiencing an issue while trying to install Creo 7.0.8 on my machine. When I run setup.exe as an administrator, nothing launches — no installer window or error message appears.
Interestingly, I was able to install Creo 11 without any issues, but my professor requires us to use Creo 7 for the course.
I’ve already reviewed and followed the suggested steps in the following PTC Community threads:
CREO 7 Installation on Windows 11
PTC Creo 7 setup.exe not running
I’ve also consulted with classmates and others familiar with Creo, but haven’t found a working solution yet. Do you have any up-to-date advice or workaround that might help resolve this issue?
Thank you in advance for your support.
Please try this release, as the release you are attempting to install may not be supported on your Windows:
https://apps.ptc.com/schools/MED-100WIN-CD-440_7-0-12-0_Install-from-web.exe
~Alex
Hi @�M_12953395
Thank you for your question.
Best regards,
~Alex
