Can you please provide me the LEGO EV3 mindstorms kit Library
I want the latest library because in my robotic model I have to use that parts which are not available in the old existing inventory of LEGO provided on: Software | PTC at the end of the page in the file > 2015 FTC Tetrix Robot Kit of Parts, after downloading that it has a LEGO inventory also(the old one).
I'm not sure this will help, but I just bought from Amazon Kindle the cited book which seems fairly up to date. Also Lego is coming out with Lego Boost http://www.theverge.com/ces/2017/1/4/13920762/lego-boost-robotics-programming-set-robot-cat-guitarhttp:// and https://www.lego.com/en-us/boost which may be less expensive than EV3 models which are running $300-500 depending on how many motors and sensors you buy.
