I have Creo M030 but cannot get it to run due to a licence issue. Cannot find out a way to download a new licence
HELP!- I think I can use an explanation mark in this context.
How are things? It's good to see you are still plugging away.![]()
You can register for Creo 3.0 using the link below. You should then receive a product code to re-license your existing software. It might be worth downloading and installing the latest build. Keep up great work. ![]()
I had the same problem and a quick email to ptc academic sorted out a new licences and a link to the latest release too.
