I installed Creo 3 with the provided license key, and I'm getting this error when trying to run it. I'm not really sure how to fix this.
Michael,
A sure fire way to fix this is to go to the folder: C:\ProgramData\PTC\Licensing and delete all the licensing files there.
Now reinstall Creo and you should be all fixed.
Me too. Exactly the same issue.
Hi Shreyas,
Did you have Creo 2.0 installed on your computer before? I think this might have something to do with it.
Thanks!
I currently have 2.0 and am updating to 3.0 as we speak.
I never saw that problem though.
BTW: I am using the college/university link, maybe the issue is K-12 link only?
Cai,
It depends if you deselect the old Creo 2.0 license while installing or not. If you do , there should be no problems but if you don't then it will come up with this error.
I also have the same issue
Michael,
Just FYI, C:\ProgramData is usually a hidden folder. The first part of this guide shows how to unhide it:
http://apps.ptc.com/schools/references/support_programdata.pdf
