License re-installation required each time I switch from university site use to home use
JS_10175939
3-Newcomer
Hello, Would you help me please?
I have the student version installed for my degree course and have different locations from which I access the license.
Each time I move location, the software requires that I re-install the license.
Is there a way around this please?
Thank you
John
I guess that university Creo license is floating one. Therefore you can contact university CAD admin and ask him to borrow university Creo license for your personal computer.
Martin Hanák
8 REPLIES 8
path to license is defined in parametric.psf file located in Parametric\bin subdirectory.
Info is available in two following lines:
ENV=PTC_D_LICENSE_FILE-=...
ENV=CREOPMA_FEATURE_NAME=...
Please put parametric.psf file into zip archive and upload zip archive.
Martin Hanák
Hello, zip file as requested.
John
John
I can see following line in parametric.psf ...
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BK700908EDSTUDENTEDUNI_license.dat;C:\ProgramData\PTC\Licensing\BK800908EDSTUDENTEDUNI_license.dat;C:\ProgramData\PTC\Licensing\BK700908EDSTUDENTEDUNI_license.dat
3 license files are mentioned
Info:
  • 3rd entry is duplicate of 1st entry
  • BK700908EDSTUDENTEDUNI_license.dat contains license which enables you to launch Creo up to release 7.0
  • BK800908EDSTUDENTEDUNI_license.dat contains license which enables you to launch Creo up to release 8.0
Also I can see following line in parametric.psf ...
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student6 ()
Info:
  • when you start Creo (which release ?), it looks in the license file and looks for the line INCREMENT CREOPMA_Student6
  • if Creo locates INCREMENT CREOPMA_Student6 then it starts successfully
Note no.1:
The following line is sufficient
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BK800908EDSTUDENTEDUNI_license.dat
Note no.2:
It is necessary to check whether BK800908EDSTUDENTEDUNI_license.dat contains INCREMENT CREOPMA_Student6
Note no.3:
Every INCREMENT block contains HOSTID=PTC_HOSTID=xx-xx-xx-xx-xx-xx key, where xx-xx-xx-xx-xx-xx is physical address of network card.
It is necessary to check whether xx-xx-xx-xx-xx-xx is equal to physical address of your network card.
Network card information can be displayed using command ipconfig /all
You can also forward information into ip.txt file using command ipconfig /all > ip.txt
If you will send me BK800908EDSTUDENTEDUNI_license.dat and ip.txt, I can provide you more information.
Martin Hanák
Hello, Thanks for your help.
I have attached the license email, not sure where to access the IP.txt file?
I am using creo 7, as it is compatible with the version on the uni computers, so I'm not sure where version 8 came from.
Creo works fine on my machine as long as I am at home, as soon as I move to another site such as UNI or at work, I need to re-install the license. Then when I get home I need to repeat the exercise.
The license files you mentioned:
  • BK700908EDSTUDENTEDUNI_license.dat contains a license which enables you to launch Creo up to release 7.0
 and the other version 8 code shows up as incorrect license files, forcing me to re-install the license.
Don't really know if I'm being clear about the problem?
license file sw_license_email_5666539.dat contains CREOPMA_Student6 license, that's OK.
License CREOPMA_Student6 is generated for Creo 7.0 and for physical address of network card C6-D7-8A-1F-9A-EB
Please run following command from Command prompt window at home and at university, too.
In my case the file is saved in C:\Users\mh directory.
It is necessary to check whether ip_home.txt and ip_uni.txt contains physical address C6-D7-8A-1F-9A-EB
Please upload both files.
Martin Hanák
Hello Martin.
I have since discovered that the student edition does not provide sufficient licensing options to allow meaningful progression in the Creo CAD module, i.e. inaccessible mold creation and analysis functions.
As a result, I am now forced to utilise the on-site CAD stations, which is extremely inconvenient for a part-time student working full time.
Thanks for your help but I shall not be using this particular software any longer.
John
Martin Hanák
Martin, you are a lifesaver, thank you. I shall see if they allow me access.
John
