Licensing Error Creo 7.0.2.0
TZ_9789274
3-Newcomer
I'm trying to download, install, and use the student version of creo parametric. I successfully downloaded it 3 times now but each time had an error "0x06000012" when trying to run the software each time. I deleted everything again to try and resintall but now I'm getting a license issue. I'm trying to use Creo 7.0.2.0, with the license code BK700908EDSTUDENTEDUNI and when I hit install licensing it says "Error!"
2 REPLIES 2
Hi @TZ_9789274
For error 0x6000012
  • Uninstall PTC Quality Agent from Control Panel > Programs and Features
  • Re-install the PTC Quality Agent using qualityagent_64.msi file from install > addon folder from the downloaded cd image.
I hope this helps.
Vipul
