I downloaded the student version 6.0.2.0 and I got a license file :
sw_license_email_4524220.dat which I copied to C:\ProgramData\PTC\Licensing
In C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf I modified following lines:
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\sw_license_email_4524220.dat
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student6 ()
according recommendations from MartinHanak.
But I allways get the message:
if I start Creo.
I send you the files parametric.psf and sw_license_email_4524220.dat
and a text file ipconfigResult.txt which contains the result of ipconfig /all from my laptop so you can
check if I missed something important.
BTW: I changed the extensions of the files all to txt otherwise upload is not allowed!
thank you for helping
Tobias Mayr
License request failed for feature
if I start Creo.
Tobias Mayr
disable following network adapters
Ethernet-Adapter Bluetooth-Netzwerkverbindung:
Drahtlos-LAN-Adapter LAN-Verbindung* 5:
Drahtlos-LAN-Adapter LAN-Verbindung* 3:
Upload std.out file ... it is located in startup directory and contains startup error message.
i have also same problem. any one can known clear this issue please tell.
Creo 6.0.2.0 installer places license file into C:\ProgramData\PTC\Licensing directory.
On your pictures I can see C:\Program Files\PTC\Creo 6.0.2.0\Common Files\afx\License.txt. This file does not contain Creo license.
1.]
Look what's in C:\ProgramData\PTC\Licensing directory. If it contains valid license file (name of the file is something like BE600908EDSTUDENTEDK12_license.dat -OR- BK600908EDSTUDENTEDUNI_license.dat) then you can proceed with step 2.
2.]
Open C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file in Notepad.
Check&modify two following lines.
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\licensefilename.dat
Note: Your license file must contain line beginning with INCREMENT CREOPMA_Student6.
I did as you said. but again i get an something error message. and I've attached those doccuments with this
please modify my instructions according to your current "situation".
1.]
I suppose it is stored in C:\ProgramData\PTC\Licensing directory.
2.]
Modify C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file:
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\sw_license_email_4713272.txt
ENV=CREOPMA_FEATURE_NAME=CREOPMA_TRIAL ()
Please remove INCREMENT CREOPMA_Student6 text from C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file !!!
NOTE : I have created the word "ProgramData" myself. and there is not even a file called "Licensing"., I created it myself and update it in sw_license_email_4713272. is there any problem?
but it is worth noting that i did this once you replay the firs time.
please show the contents of C:\ProgramData\PTC\Licensing directory in File Explorer (see following picture).
Note:
You can enlarge Warning Message List dialog box to display whole error message in single window.
I have done now all things you said in this message. and as you said in the C:\ProgramData\PTC\Licensing, I have made BE600908EDSTUDENTEDK12.
but back to the issue
I have attached all screenshots related to this.
please perform the following steps.
1.]
Delete system variable PTC_D_LICENSE_FILE.
Delete user variable PTCNMSPORT.
Restart PC.
2.]
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BE600908EDSTUDENTEDK12_license.dat
Note 1:
Note 2:
To upload any file, you have to pack it into zip file and upload this zip file.
I've modified everything you said. But again, there is such a warning message.
modify C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file:
ENV=CREOPMA_FEATURE_NAME=CREOPMA_SchoolSTD6 ()
Note:
To upload any file (for example .txt, .dat, .prt.1, .asm.1, .drw.1, ...), you have to pack it into zip file and upload this zip file.
Mr, MartinHanak. finally all issues cleared. thank you somuch for your help.
Hello sir,
my student edition 6.0.2.0 license is expired. can i renew thi now
@mnhari97 wrote:
Hello sir,
simple solution
I have the same issue , please see the attached screen shots....
Did all what you have described …..
what else should I change in licence file
1.]
You must not modify the contents of the license file !!!
2.]
Open sw_license_email_4726815.dat attached to email in Notepad and copy/paste its contents into C:\ProgramData\PTC\Licensing\sw_license_email_4726815.dat file.
3.]
Start Creo.
@roshreji wrote:
ok...
didn't work after that too....
your C:\ProgramData\PTC\Licensing\sw_license_email_4726815.dat file containst Creo 5.0 license (CREOPMA_SchoolSTD3, code 36.0). You cannot use it to run Creo 6.0.
If you want to use Creo 6.0 then:
1.] you have to move all files from C:\ProgramData\PTC\Licensing directory temporarily into another directory.
2.] install Creo 6.0
K-12 students can use Product code BE600908EDSTUDENTEDK12
University students can use Product code BK600908EDSTUDENTEDUNI
3.] move files mentioned in step 1. back
Please read:
https://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo6_unistudent_standard.pdf
Thank you,
initially when I downloaded the application they sent me the licence for creo 5.
I did as you told. Its working perfect now .
your license file file contains Creo 4.0 license (CREOPMA_Student3, code 35.0). You cannot use it to run Creo 5.0+ version.
