Licensing Problem with Creo 6 Student Version License request failed for feature
TobiasMayr
2-Explorer
I downloaded the student version 6.0.2.0 and I got a license file :
sw_license_email_4524220.dat which I copied to C:\ProgramData\PTC\Licensing
In C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf I modified following lines:
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\sw_license_email_4524220.dat
ENV=CREOPMA_FEATURE_NAME=CREOPMA_Student6 ()
according recommendations from MartinHanak.
But I allways get the message:
if I start Creo.
I send you the files parametric.psf  and  sw_license_email_4524220.dat
and a text file ipconfigResult.txt  which contains the result of ipconfig /all  from my laptop so you can
check if I missed something important.
BTW: I changed the extensions of the files all to txt otherwise upload is not allowed!
thank you for helping
Tobias Mayr
22 REPLIES 22
if I start Creo.
Tobias Mayr
disable following network adapters
Ethernet-Adapter Bluetooth-Netzwerkverbindung:
Drahtlos-LAN-Adapter LAN-Verbindung* 5:
Drahtlos-LAN-Adapter LAN-Verbindung* 3:
Upload std.out file ... it is located in startup directory and contains startup error message.
Martin Hanák
mnhari97
6-Contributor
(To:TobiasMayr)
i have also same problem. any one can known clear this issue please tell.
Creo 6.0.2.0 installer places license file into C:\ProgramData\PTC\Licensing directory.
On your pictures I can see C:\Program Files\PTC\Creo 6.0.2.0\Common Files\afx\License.txt. This file does not contain Creo license.
1.]
Look what's in C:\ProgramData\PTC\Licensing directory. If it contains valid license file (name of the file is something like BE600908EDSTUDENTEDK12_license.dat -OR- BK600908EDSTUDENTEDUNI_license.dat) then you can proceed with step 2.
2.]
Open C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file in Notepad.
Check&modify two following lines.
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\licensefilename.dat
Note: Your license file must contain line beginning with INCREMENT CREOPMA_Student6.
Martin Hanák
mnhari97
6-Contributor
(To:MartinHanak)
I did as you said. but again i get an something error message. and I've attached those doccuments with this
please modify my instructions according to your current "situation".
1.]
I suppose it is stored in C:\ProgramData\PTC\Licensing directory.
2.]
Modify C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file:
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\sw_license_email_4713272.txt
ENV=CREOPMA_FEATURE_NAME=CREOPMA_TRIAL ()
Please remove INCREMENT CREOPMA_Student6 text from C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file !!!
Martin Hanák
mnhari97
6-Contributor
(To:MartinHanak)
         NOTE : I have created the word "ProgramData" myself. and there is not even a file called "Licensing"., I created it myself and update it in sw_license_email_4713272.    is there any problem?
                       but it is worth noting that i did this once you replay the firs time.
please show the contents of C:\ProgramData\PTC\Licensing directory in File Explorer (see following picture).
Note:
You can enlarge Warning Message List dialog box to display whole error message in single window.
Martin Hanák
mnhari97
6-Contributor
(To:MartinHanak)
  I have done now all things you said in this message. and as you said in the C:\ProgramData\PTC\Licensing,  I have made BE600908EDSTUDENTEDK12.
but back to the issue
  I have attached all screenshots related to this.
please perform the following steps.
1.]
Delete system variable PTC_D_LICENSE_FILE.
Delete user variable PTCNMSPORT.
Restart PC.
2.]
ENV=PTC_D_LICENSE_FILE-=C:\ProgramData\PTC\Licensing\BE600908EDSTUDENTEDK12_license.dat
Note 1:
Note 2:
To upload any file, you have to pack it into zip file and upload this zip file.
Martin Hanák
mnhari97
6-Contributor
(To:MartinHanak)
I've modified everything you said. But again, there is such a warning message.
modify C:\Program Files\PTC\Creo 6.0.2.0\Parametric\bin\parametric.psf file:
ENV=CREOPMA_FEATURE_NAME=CREOPMA_SchoolSTD6 ()
Note:
To upload any file (for example .txt, .dat, .prt.1, .asm.1, .drw.1, ...), you have to pack it into zip file and upload this zip file.
Martin Hanák
mnhari97
6-Contributor
(To:MartinHanak)
        Mr, MartinHanak. finally all issues cleared. thank you somuch for your help.
mnhari97
6-Contributor
(To:mnhari97)
Hello sir,
             my student edition 6.0.2.0 license is expired. can i renew thi now
@mnhari97 wrote:
Hello sir,
simple solution
Martin Hanák
I have the same issue , please see the attached screen shots....
Did all what you have described …..
what else should I change in licence file
1.]
You must not modify the contents of the license file !!!
2.]
Open sw_license_email_4726815.dat attached to email in Notepad and copy/paste its contents into C:\ProgramData\PTC\Licensing\sw_license_email_4726815.dat file.
3.]
Start Creo.
Martin Hanák
ok...
didn't work after that too....
@roshreji wrote:
ok...
your C:\ProgramData\PTC\Licensing\sw_license_email_4726815.dat file containst Creo 5.0 license (CREOPMA_SchoolSTD3, code 36.0). You cannot use it to run Creo 6.0.
If you want to use Creo 6.0 then:
1.] you have to move all files from C:\ProgramData\PTC\Licensing directory temporarily into another directory.
2.] install Creo 6.0
K-12 students can use Product code BE600908EDSTUDENTEDK12
University students can use Product code BK600908EDSTUDENTEDUNI
3.] move files mentioned in step 1. back
Please read:
https://apps.ptc.com/schools/references/install_creo6_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo6_unistudent_standard.pdf
Martin Hanák
Thank you,
initially when I downloaded the application they sent me the licence for creo 5.
I did as you told. Its working perfect now .
I have the same issue , please see the attached screen shots....螢幕擷取畫面 2021-09-30 165821.jpg
your license file file contains Creo 4.0 license (CREOPMA_Student3, code 35.0). You cannot use it to run Creo 5.0+ version.
Martin Hanák
