Licensing error
OptimistishHerr
Licensing error
Hello all,
Yesterday I have downloaded Creo 5.0 student version and the installation worked fine.
But after opening the application it is showing that the license is not valid for this version. What should I do?
please read attached documents and check steps described in them. Next time please attach some picture reporting your problem.
Martin Hanák
Martin Hanák
Vinz
2-Explorer
(To:MartinHanak)
So frustrated with install of Creo 5.0 on Windows 10....nothing but non-specific error! messages 😞IMG_7054.JPG
MartinHanak
(To:Vinz)
check your email box ... maybe PTC sent you license file via email.
In case that you received email:
  •  save license file to disc
  • launch installation
  • do not enter Product code
  • enter path to license file to Source field
Sometimes installer has problems with network cards. Please open Command Prompt window, enter ipconfig /all > ip.txt command and upload ip.txt file. I will check its contents.
Martin Hanák
