Licensing problem with Creo 6.0
MarcTUKL
3-Newcomer
I am using Creo 6.0 with my laptop connected to a dockingstation and it´s working fine. Ethernet and wireless. Both is working. If I disconnet the laptop from the dockingstation i get the attached error when I start Creo.
regards,
Marc
8 REPLIES 8
rpathare
(To:MarcTUKL)
@MarcTUKL Check whether the below steps resolves the problem:-
Check whether the option Allow the computer to turn off this device to save power for the Ethernet Adapter LAN is disabled
  • Go to Device Manager > Network Adapters
  • Select the network card used to generate the license file and go to Properties.
  • Select Power Management and uncheck the option "Allow the computer to turn off this device to save power"
MarcTUKL
3-Newcomer
(To:rpathare)
I've tried that, but it doesn't change anything.
regards,
Marc
maybe MAC address 98-E7-43-29-CF-E2 shown on the picture is related to docking station, only.
Tip:
1.] put laptop into dockingstation and run ipconfig /all > ip1.txt from Command prompt window
2.] disconnect laptop from dockingstation and run ipconfig /all > ip2.txt from Command prompt window
3.] compare contents of these files (you can upload them and I will check them...)
  • look for MAC address 98-E7-43-29-CF-E2
Martin Hanák
I've attached both pictures. Funnily enough, I can't find the MAC address on either one
1.] please next time upload text files containing ipconfig output
I think you know that ipconfig /all > ip1.txt creates ip1.txt file in working directory.
2.] can you remember when and how you were connected to Internet ?
It is strange that MAC address 98-E7-43-29-CF-E2 was available during Creo installation and now it is not present. Did you disable some network card ?
Martin Hanák
The same Internet connection as now. But Creo works as long as the laptop is connected to the docking station, even though the MAC address is not correct. I have been thinking about reinstalling Creo. The question is, with or without a connection to the docking station?
I digged text information from your pictures.
Ethernet-Adapter Ethernet ... 54-B2-03-95-94-87
Ethernet-Adapter Ethernet 2 ... 54-B2-03-95-94-88 ... CONNECTED
Drahtlos-LAN-Adapter WLAN ... 4C-EB-BD-32-DE-87
Drahtlos-LAN-Adapter LAN-Verbindung* 1 ... 4E-EB-BD-32-DE-87
Drahtlos-LAN-Adapter LAN-Verbindung* 2 ... 5E-EB-BD-32-DE-87
Mobiler Breitband Mobilfunk ... 94-9F-9B-58-52-5A
... does not exist Ethernet-Adapter Ethernet 2
Drahtlos-LAN-Adapter WLAN ... 4C-EB-BD-32-DE-87 ... CONNECTED
I guess that Creo license is related to Ethernet-Adapter Ethernet 2 ... 54-B2-03-95-94-88 somehow.
... and Creo without docking station does not work, because this network card is missing.
Suggestion:
1.] disconnect laptop from docking station
2.] connect to Internet using Ethernet-Adapter Ethernet ... 54-B2-03-95-94-87
3.] disable all other network cards (ipconfig output will show only 1 network card)
4.] uninstall Creo
5.] remove license file from C:\ProgramData\PTC\Licensing directory
6.] install Creo ... you will license file related to 54-B2-03-95-94-87
Martin Hanák
Made according to the instructions, works!
Thanks a lot. Best and fastest support I ever had
Regards
Marc
