I just installed the student version of Creo Parametric V4. The tutorial explains that we can change the unit system of the software thanks to Creo Standards. However, when I choose the MKS system, a message comes up in Creo Standards : "Access denied. You must change the permission so that you can write in the folder..." .
I don't know how to resolve. Any help would be appreciated ![]()
please describe how you choose the MKS system. Attach a screenshot if necessary.
You can also attach tutorial and point to step you are doing.
I found a another solution : the one with the config.pro file. I followed this tutorial : https://cao-3d-pro.com/creo-debuter-les-reglages/
