Making extrusion shorter or longer
msmith2
2-Explorer
Hi again,
We are trying to make some REV extrusion that we downloaded a STEP file for shorter.  We were able to use the "Make Flexible" option in the menu for another part that we tried (a Tetrix axle) and it let us change the length, but it does not work for REV extrusion.
Does anyone know what we need to do to make that work?  The file we are using is here: REV 15mm Extrusion, 1m (am-2915)
Thanks!
Maddie
FTC 4962
sm
(To:msmith2)
I'll try to make a newer video for you, but check out Video Link : 4443. You'll want to FF up to 49:00 min. into the video. It will take a few minutes for the clip to buffer until you can get there.
PTC offers this component, am-2915, as a Creo model in the PTC FRC KOP.
1 REPLY 1
sm
(To:msmith2)
