i am running a emulator on a mac for windows 7 so that i can use mathcad. before u stop reading plz help, this was the cheapest way to do it since i am in college. with that said everything seems to be working fine except for the data table function. it wont let me input a table or if a table is in a worksheet it wont recognize that there is one there. i figure that it might be something not being converted in the emulator but i was wondering if there was anyway to check that it is just on the windows 7 side and not the mac side.
Firstly welcome to the forum.
Can you post an example of your Mathcad worksheet and the data you are trying to insert?
Mike
the problem is that when i click insert-data-table or right click and insert-table it just doesnt do anything. Then i tried opening a document that i did on another computer with a table in it and the table name showed up but not table. they are specific tables, just the table function doesnt work.
I'm not sure what version of Mathcad you are running, but can you try and open the attached worksheet and tell me what you see.
Mike
all that i got was Example :=, it was in red and there were several large boxes on the scene with nothing in them but their outlines were lime green. also i am running mathcad 14.0.2.5. i am wondering if i can download mathcad straight to mac. or maybe just getting a new emulator. do u have suggestions?
I have the same problem as Neville Tritch. I'm running version 15.0.0.436 on Windows 7.
When I open the Example.xmcd file I only see "Example:=" in red. When I left click the red "Example:=" I see there is a box, and I get this warning text in a yellow pop-up box "Value cannot be null. Parameter name: pUnk"
Hope someone can help.
Problem fixed by uninstalling and removing everything regarding Mathcad, and doing a new installation.
