Use this link (to find the 7th version): https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp
Thank you for the link, it worked in I have downloaded Mathcat 7.
When I start op the program, I go through the set up section again. I choose "Active Purchased Licens" put my accounts details in, and then I wrote my licens code in. But when I want to Aqquire licens it says "Rodeelement needs" and I get the an e-mail with that says:
"Attached, please find your requested license file for Mathcad, which enables you to run the Mathcad application.
If necessary, you can now complete the installation and licensing process with this file.
Save this file to any location (e.g. c:/temp or any other location of your choosing). Please be sure to remember where you saved the
file since you will need to reference it later. The file must be on the same hard drive as your installation of Mathcad. When you attempt
to launch Mathcad, you will be asked to specify the path to this file.
Please do not open the attached file through your email application as that can corrupt the file. Be sure to save it to disk before opening
or unzipping it."
I have done this, but it still want work.
I hope you can help me!
And what happens when you start the program after you have received the license file?
Nothing happens. I get a mail with a licens file and i Save that on my computer deskboard. Then i try again with the file i just recived and saved, but it still want work.
Im thinking of resetting my computer from scratch to see if that will help.
