I bought the student version of Mathcad prime 8 in April 2022. I have been using it for a couple of months without any issues. Recently, the program does not open anymore. Also my Mathcad file do not open either. I tried to uninstall it and reinstall it again but it did not work. Can someone help me fix this problem please?!
I am using Windows 10 (64bit). My license is one year and has not expired.
Abdullah Al Rufaydah,
try solution mentioned in https://community.ptc.com/t5/Mathcad/Mathcad-Prime-4-0-doesn-t-start-anymore/td-p/492614 discussion.
Thanks A LOT Martin.
I just deleted the config file in that directory and Mathcad recreated it and it is working fine now.
As simple as that !
Thanks again
The same issue affected me with the full version of Mathcad Prime 8 on Windows 10 20H2. This solution worked, too.
"Mathcad Installation & Licensing Support Center": https://support.ptc.com/support/mathcad_supportCenter.htm
