I'm attempting to merge a series of parts in an assembly.
I have assembled all the .prt in the .asm and all parts are fully constrained.
I have then assembled a blank .prt into the assembly. I then follow the procedure: Component dropdown > Component operations > Merge > Blank .prt in model tree > Ok > Parts to be merged in model tree > Done.
The blank .prt which I have attempted to merge the existing parts into then fails to regenerate.
I have checked that all relevant files are using the same units from File > Prepare > Model Properties.
What should I do to resolve the problem?
Thanks.
May be multiple reasons for the merge failure.
Have a look at this tutorial, it may help
