As i said in the subject, my CREO Parametric 3.0 version crashes when assembling with a pin as a joint. Like if i try to transform a link between two assembled parts into a pin, a particular message pops (you can see it on the picture below). As soon as i click on OK or on the cross of this message, my CREO document instantly disappears. I tried to reinstall CREO to see if i deleted an useful document but nothing changed. Coud you help me ? What can i do ?
Hoping someone will be able to save me, have a good day.
NTA
did you look in the knowledge base?
When searching the error message, the following article is available : https://www.ptc.com/en/support/article/CS259139
Hello Remy,
I'm sorry but i don't know where to find the knowledge base. Moreover, i couldn't find the solutions to solve my problem on the link you shared.
NTA
Thank you guys, that was the issue.
Sincerely,
NTA
You may browse to this page and access the url: https://www.ptc.com/en/support/
bookmark it.
