Need help downloading creo 3.0 student edition
ksengkit
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
This shows up when I try clicking on the pdf file to download the Creo 3.0 student edition. Tried downloading the older versions and it still shows this. Any help would be appreciated. Thanks!
ryankelley
(To:eelezaj)
Kong Seng Kit‌ / Evan Elezaj‌ - can you both clear your cache and refresh? I'm able to see the following page after successfully logging into my PTC support account:
11 REPLIES 11
Can you provide the actual link location embedded within the PDF so we can track down this issue? We have made several changes to the redirection rules effecting several pages and I want to make sure this was resolved. Thanks.
Hi Ryan Kelley,
This is the link that was given in the Creo 3.0 download pdf file http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp
thanks for giving .......very much thankyou
this is the link i got and im having the same problem
Same link and having the same exact problem. I have tried accessing it on several different computers and all had the same problem.
ryankelley
(To:eelezaj)
Tried resetting the cache and restarted computer. After several hours it finally let me in to the download center. Thanks so much to the help!!!
ryankelley
(To:eelezaj)
No worries, looks like it just needed a little time to work it's MAGIC!
how to get this page
how can i get licence to creo 3.0
