New to Creo
ptc-4307516
New to Creo
I am brand new to using Creo for FTC. I have downloaded the program and the kit of parts. I have gone into Creo and set the parts as my working directory. When I try to open any part, I receive the message that the filee "cannot be retrieved". What am I doing wrong?
I had this problem. Be sure you are using Creo Parametric in order to be able to open the kit of parts and use them in an assembly.
sm
(To:ptc-4307516)
Did you get an academic/student version of Creo through the PTC FIRST Software page? Curious if you might have downloaded and installed a trial version which will not open the "student" models.
Try dragging the message area to be taller so you can see the complete message.
ptc-4307516
(To:sm)
I did download it from this site but did it last year. I am not sure if it makes a difference. I have uninstalled the software and am downloading it again. Will make sure that is not the problem.
