Not Able get the data in the Mashups for SimpleAndriondApp and EnhancedAndriodApp
akhan1
I have created local thingworx instance as well as cloud instance ..
Downloaded the apk and installed in my andriod device .
And imported the .xml file and created mashup .. binded  with IMEI and checked the Appkey ... etc ...
But i am unable to get the data in the mashups ... There are no logs for it that is the reason i could give any logs here ...
only thing i am getting in mobile device is to check the IP key etc to .. which i did for multiple times .
could any one help please Adrian Petrescu​   Veronica Mihai
let me know anything i am missing
Thanks in advance ...
ssg1
7-Bedrock
(To:akhan1)
Amjath,
Eben i faced this issue once . Plz check
System->SubSystems->PlzatformSubsytem->Configuration->Allow Request Method Switch is checked and Filter Content-Type unchecked.
after doing the change , restart your Tomcat.
6 REPLIES 6
adrianpet
(To:akhan1)
       I am working on this as we speak. I will further investigate this and let you know as soon as possible. If I won't be able to respond today, I will send you an answer by the end of Monday night.
Thank you,
Adrian
Aanjan
(To:akhan1)
Amjath, while Adrian checks on his end, I have a quick question - do you have any form of proxies or firewall involved in your instances? Can you try turning them off temporarily and retry? This app should connect to a Thing, right? Does the isConnected property for the Thing ever show up as true?
akhan1
(To:Aanjan)
no Aanjan Ravi​ i don't have any proxie ..
and no firewall blocking
ssg1
7-Bedrock
(To:akhan1)
Amjath,
akhan1
(To:ssg1)
Sugunasagar SG​ Thanks for your Help it worked.
vmihai
(To:akhan1)
Hi Amjath,
I apologize for the late reply. If you are using a ThingWorx 6.0 or higher, please apply what Sugunasagar suggested in the reply above. No need to restart your Tomcat though.
Let me know if this fixes the issue,
Veronica
