PTC Creo 9.0 University Student Edition Premium / Installation problems
RS_7919254
2-Explorer
Dear Sir or Madam,
I purchased the Creo Student Premium Edition on 26.07.2022 and sent my certificate of enrollment to ptc.nam@digitalriver.com on the same day . On 29.07.2022 I received the order confirmation with my product code.
To my problem:
After calling the installation, I was able to generate the license with my received product code. However, in the next step, the application selection is empty and I could not proceed with the installation. I tried it again today and now the error message "You have reached the maximum number of license requests available for your product type" comes up when creating the license.
I hope you can help me.
Kind regards
Roman Sauer
@RS_7919254 wrote:
hmm unfortunately I come to the same result
maybe installation zip file is corrupted, please download it again from https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp page.
How did you unzip zip file ? I use 7-zip application.
Martin Hanák
8 REPLIES 8
please provide detailed description of your computer configuration.
Martin Hanák
Alienware m15 Ryzen R5
Windows 11 home
AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz
16,0 GB RAM
64-Bit-Betriebssystem, x64-basierter Prozessor
Windows 11 home
16,0 GB RAM
maybe Windows 11 home is the root of the problem.
What Creo version did you install ?
Please provide detailed description of installation procedure. Include screenshot pictures, too.
Make a backup copy of license file located in C:\ProgramData\PTC\Licensing directory.
Open license file in Notepad and publish screenshot picture of Notepad window.
Martin Hanák
Unfortunately I deleted the generated license file.
But I got to this point of the install:
However, I received an automatic email from academicsupport@ptc.com with a license file. But I only get to the same pointScreenshot 2022-08-02 095340.jpgScreenshot 2022-08-02 094942.jpg
Here are the notepad screenshots of the license file from the email:
Screenshot 2022-08-02 095819.jpgScreenshot 2022-08-02 095852.jpgScreenshot 2022-08-02 100005.jpgScreenshot 2022-08-02 100035.jpgScreenshot 2022-08-02 095914.jpg
below you can find recommended installation procedure.
  • create C:\PTC directory
  • set access rights to C:\PTC directory to Full control for Everyone
  • create C:\PTC\Creo9 directory
  • save license file into C:\PTC directory ... for example you can use mylicense.dat name
  • download MED-100WIN-CD-460_9-0-0-0_Win64.zip and save it into C:\PTC directory
  • unzip MED-100WIN-CD-460_9-0-0-0_Win64.zip into C:\PTC\MED-100WIN-CD-460_9-0-0-0_Win64 directory
  • run setup.exe from C:\PTC\MED-100WIN-CD-460_9-0-0-0_Win64 directory
  • do not enter Product code
  • add path to license file into following area (for example you can use C:\PTC\mylicense.dat) ... remove invalid entries if necessary
  • continue with installation
  • enter C:\PTC\Creo9 installation directory instead of C:\Program Files\PTC
Martin Hanák
Martin Hanák
Thank you very much!
