@RS_7919254 wrote:
hmm unfortunately I come to the same result
maybe installation zip file is corrupted, please download it again from https://support.ptc.com/appserver/auth/it/esd/academicFree.jsp page.
How did you unzip zip file ? I use 7-zip application.
please provide detailed description of your computer configuration.
Alienware m15 Ryzen R5
Windows 11 home
AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz
16,0 GB RAM
64-Bit-Betriebssystem, x64-basierter Prozessor
Windows 11 home
16,0 GB RAM
maybe Windows 11 home is the root of the problem.
What Creo version did you install ?
Please provide detailed description of installation procedure. Include screenshot pictures, too.
Make a backup copy of license file located in C:\ProgramData\PTC\Licensing directory.
Open license file in Notepad and publish screenshot picture of Notepad window.
PTC Creo 9.0 University Student Edition Premium
Unfortunately I deleted the generated license file.
But I got to this point of the install:
However, I received an automatic email from academicsupport@ptc.com with a license file. But I only get to the same point
Here are the notepad screenshots of the license file from the email:
below you can find recommended installation procedure.
Thank you very much!
