I'm trying to install PTC Creo 9.0 on my Windows 10 Pro 22H2, but the setup.exe file doesn't work. It doesn't even run when I run it as administrator, even if I disable the firewall application.
Which folder are you running the installer from?
Hi, I'm running it from Downloads folder. Does it have to be run from any specific folder?
It worked, thank you so much!!
