Hi
I've just reinstalled Creo Parametric 2.0 a couple of times now but I'm still facing the same problem.
I am not sure what would be the problem but the details are as follows:
I clicked Creo Parametric to run. Nothing happens.
I am running windows 8 64 bit.
It worked fine before this.
Cheers.
Please open a support request at http://www.ptc.com/go/academic-support and someone from the support team will contact you.
Amir,
This is most likely an issue with your graphics card/driver or an incomplete installation. Please open a support request at http://www.ptc.com/go/academic-support and someone from the support team will contact you.
Be sure to include information about the edition and build code of Creo that you are trying to install. Also any change you have made that may have caused it to stop working (maybe you updated or changed your graphics driver for example).
Adam
We have seen this problem if the computer image does not include a config.pro file.
I have a shortcut on a flash drive that includes a config.pro file, and that can get the computers to start Creo.
Search your computer for config.pro. If it does not have one, you will need one.
FYI - Some info on config.pro files:
Hi guys
I managed to get the program running for the first time after numerous reinstallation. But now the program shut down after displaying a message about Quality Agent not being able to run.
I've been looking everywhere to get the quality agent installer file or something but haven't found anything yet.
Do you guys have any ideas where I could get it? Is it in the same installer for the Creo?
Update:
I've managed to reinstall Quality Agent but its not working.
The error is 0xc6000005
