PVS/PVZ format: To access the structure of the file.
SB_10165578
Hello folks, I am able to load the PVS/PVZ files in Creo parametric and I am trying to access its data or the structure of the model components to perform certain operations but I am not able to get any documentation for the PVS/PVZ files. Do anyone have any idea "in what form do the data in PVS/PVZ file format is present ? is it solid or surface or tessellated ?" Is it possible to access the data in the PVS/PVZ file ? If it is then which toolkit API should I use ? having a proper documentation.
5 REPLIES 5
Here are some helpful articles:
SB_10165578
(To:VladimirN)
Thank you @VladimirN for the reply. I went through those links and helped me in getting basic understanding. Is there any way I can get the geometry data from the PVZ/PVS file ? That's what I am aiming for
what Creo Parametric release do you use ?
In Creo Parametric 8.0 I can import PVZ part file as geometry or facets. I hope the same functionality is available in older releases.
Please provide more details about your "project".
Martin Hanák
Thank you for the reply @MartinHanak . I am using Creo parametric 5.0 C++ toolkit to get solid and surfaces data of 3D model for e.g. Creo assembly. I traverse this assembly and get facet data i.e. tessellated. Now going forward, I need to get facet data from PVZ file. So my questions are:
1. Can we get tessellated data from PVZ file using Creo parametric 5.0 C++ toolkit?
2. If possible, can you please share some links where we can get more information or documentation to read PVZ data
I guess that the PVZ / PVS format is not public, i.e. only the PTC knows the definition of the format. Please contact PTC Support for more information.
Martin Hanák
