Predictive weather mashup exercise
kkabak
I am having trouble with the 2 services which get the weather information from open weather and yahoo weather site. I have implemented them just like in the tutorials, but I´m receiving the following error codes:
[context: com.thingworx.webservices.context.HttpExecutionContext@511e1e46][message: Execution error in service script [WeatherThing GetYahooWeatherInformation] : Wrapped org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Content is not allowed in prolog. Cause: Content is not allowed in prolog.]
[context: com.thingworx.webservices.context.HttpExecutionContext@6b492dd3][message: Execution error in service script [WeatherThing GetOpenWeatherForecastData] : Wrapped java.net.MalformedURLException: no protocol: api.openweathermap.org/data/2.5/weather?lat=39.0&lon=-111.0&units=imperial&type=accurate&mode=xml Cause: no protocol: api.openweathermap.org/data/2.5/weather?lat=39.0&lon=-111.0&units=imperial&type=accurate&mode=xml]
Can you please advise?
Two days ago the services were functional and I did not change anything.
Enclosed you can find the project files.
Thank you,
Kübra Kabak
vmihai
(To:kkabak)
The Open Weather API requires an API Key now. You can create yourself one at this website or you can use one that I have created for test  4abc8a3c9f101ccf9c7cfe7cbf3dfed7.
You need to append  &APPID=4abc8a3c9f101ccf9c7cfe7cbf3dfed7 (or your own api key value) at the end of the Open Weather URL in  the GetYahooWeatherInformation service at line 97
   var params = {
url: "http://api.openweathermap.org/data/2.5/weather?q="+cityName+"&type=accurate&mode=xml&APPID=4abc8a3c9f101ccf9c7cfe7cbf3dfed7"
/* STRING */,
timeout: 60 /* NUMBER */
And in the GetOpenWeatherForecastData; service at line 6
var params = {
url: "http://api.openweathermap.org/data/2.5/forecast?lat="+lat+"&lon="+long+"&units=imperial&type=accurate&mode=xml&APPID=4abc8a3c9f101ccf9c7cfe7cbf3dfed7" /* STRING */,
timeout: 160 /* NUMBER */
You shouldn't have any more errors now.
Veronica
vkunwar
(To:vmihai)
I am facing the same problem. I have followed the above instruction but still I am facing the same problem.
I also facing problem in server authentication, I have my own username and password but sometime a pop up comes which require authentication.For that it doesn't take my username password.
can you please advice?
vmihai
(To:vkunwar)
Hi Vinay,
Please note that yahoo weather api is no longer in service. Please check the post below for a working implementation of the OpenWeatherMap API service call :
https://community.thingworx.com/message/43348?et=watches.email.thread#43348
Let me know if you are in need of further assistance.
Veronica
