Pro/Program is Not Keeping Relations
tfilipiak
Student edition Creo Parametric 8.0.  Pro/Program will save the Input section but not the relations.  It also is not regenerating the model.
I guess Student license does not contains ASSEMBLY module. Therefore you can use ProProgram in Part mode, only. Relations must be defined in Relations dialog box.
Martin Hanák
