I cant open CREO parametric (School Edition), i didnt get a message it just doesnt start...
i tought it can be a Compatibility issue but i already check it and .. nothing happends.
Please Help.
Im using a Macbook Pro, but i have Windows 7 home premium on it.
Thank you
Looks like your installation did not complete then, you should try reinstalling. You should see many folders inside of M020.
This sounds like a graphics issue. I am not familiar with the way Windows 7 works on a MAC, is it possible for you to update the graphics driver? That is the first step I would take.
If the graphics driver can't be updated, try this:
Im sorry but i cant finf de Folder "Text" ![]()
And i dont think it would be the graphic driver because i just downloaded
The path will be C:\program files\PTC\Creo 1.0\Common Files\<BUILD NUMBER>\text, where <BUILD NUMBER> is the build number of the Creo version that you installed.
For example, it may be C:\program files\PTC\Creo 1.0\Common Files\F000\text or if you have installed the latest M020 version it would be C:\program files\PTC\Creo 1.0\Common Files\M020\text.
Hi, sorry again
im already in E:\program files\PTC\Creo 1.0\Common Files\M020\ but i cant fin the folder. on M020 i just have "Demos, UFX, uninstall" folders.
I dont know what to do and i really need creo
thank you
Thanks a lot ! it was the instalation problem
