Problem of sweeping
JK_95.25
Problem of sweeping
Hello Everyone,
I have a problem of sweeping. When I choose the option 'solid', the option material removal is activated by default and I had no way to change that. I use Creo parametric 6.0 for students.
Could you help me please?
Dale_Rosema
(To:JK_95.25)
Are you in a part or an assembly? If you are in an assembly, you cannot add material in Creo.
4 REPLIES 4
@JK_95.25 wrote:
Hello Everyone,
please explain what are you doing.
Do simple test ... create new part and start Sweep feature creation.
Martin Hanák
JK_95.25
(To:MartinHanak)
it worked in the part. Thanks
Dale_Rosema
(To:JK_95.25)
JK_95.25
(To:Dale_Rosema)
i'm in an assembly. Ok i see.
