I am trying to run some mock analysis on a wing design to get familar with the program. When I try to run FloEDF's wizard it starts to load but then give me an error of "There must at least one component for a FloEDF.Pro analysis." Can you help me figure this out?
Attached is a screen shot of what I am trying to analyze and the message that keeps popping up.
Do you have an assembly open in ProE?
Hi all,
To run a flow analysis, you need to do a number of things prior to running it.
1) Flo can only work on an assembly
2) Flo can only be used on solid components
3) you need to save the object prior to running the model
4) you need to make sure the model is fully regenerated.
Please give those items a check and try and run it again.
If it fails....send the model to - and I can take a look.
Mark
