Problems installing creo 3.0. 197/5000
xarmengol
I installed it without errors but when I start the application I have a 'stop.exe' error. System error is missing << ucuore46.dll >>, It says that it should be installed to solve the problem, but it remains the same.
1 REPLY 1
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS54594 document contains two tips ...
1.] clean user profile
  • open Windows Explorer window
  • go to %APPDATA% directory
  • remove PTC sub-directory
2.] modify PATH variable
  • open Command Prompt window
  • run rundll32 sysdm.cpl,EditEnvironmentVariables command
  • now you can set/modify PATH variable on Personal or System level
  • be carefull and do not destroy current definition of PATH variable
  • add following paths at the beginning of PATH variable definition
  • 32-bit Windows ... Creo3_loadpoint\Creo 3.0\Mxxx\Common Files\i486_nt\lib
  • 64-bit Windows ... Creo3_loadpoint\Creo 3.0\Mxxx\Common Files\x86e_win64\lib
MH
Martin Hanák
