I installed it without errors but when I start the application I have a 'stop.exe' error. System error is missing << ucuore46.dll >>, It says that it should be installed to solve the problem, but it remains the same.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS54594 document contains two tips ...
1.] clean user profile
2.] modify PATH variable
MH
