if you want to install Creo Parametric 11.0 then read following documents.
https://apps.ptc.com/schools/references/install_creo11_schools_standard.pdf
https://apps.ptc.com/schools/references/install_creo11_unistudent_standard.pdf
Hello @YZ_12234257,
It looks like you have a response from a community member. If any of these replies helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
