Quality Agent issue
AS_9730410
2-Explorer
Quality Agent issue
After installing creo parametric 7.0 (academic free software) , when I run the software I get a pop up message to register as a quality agent when I click yes then another message gets popped up saying cannot register insufficient user access software shutting down how can I resolve this issue. I also made the quality agent setup run , but it didn't resolve the issue
please help
3 REPLIES 3
@AS_9730410
Kindly follow the steps mentioned below using administration privileges
• Uninstall PTC Quality Agent from Control Panel > Programs and Features
• Re-install the PTC Quality Agent using qualityagent_64.msi file from Install > addon folder from the downloaded cd image.
Thanks.
Thanks for your response , If you don't mind can you help me with another
issue.
The issue is the software crashes (parametric 7.0 ) every 15 - 20 minutes
and gives a pop up message of trackback created at this location, can you
please help me resolve this issue.
thanks
I think it's better to open another topic because this one is dedicated to another concern.
Thanks.
