I'm trying to remake the template for my team, since we changed our team name and logo. Does anyone know how to get Quantity of a part or assembly in the drawing frame table? &qty doesn't seems work.
Gary, are you putting the parameter into a repeat region? That is the only way it will work. I will look for a quick tutorial on this for you later today.
