In response to a suggestion from Tim Brotherhood, I am posting here a zip file containing the Creo model (Creo2 Parametric Schools Edition) of the Quartz Clock Movement that I recently posted in a photo album. I hope it may be of use to others.
The clock spindle is 7.5mm diameter, and the nut is currently set in a position to accomodate 3mm thick material but can of course be edited if needs be.
