Hello all, I'm having problems increasing the final resolution of photolux rendered assemblies. Currently, a 150mm x 150mm (70x70x70 assembley size) image at the highest settings, including the rendering of 'transparent' materials takes about 4-5 hours, yet only produces a 72dpi image. I'm using Wildfire 4.0 MO92, Schools Edition. Ultimately I'd like to produce images that are at least 300dpi, so: A: can I increase the output resolution size (in dpi)? B: is it possible to export .spl file extensions, so as to import into 'Blend'? C: Is anyone currently running ProE across a Linux based Beowulf Cluster, particularly for the rendering exercise? Many thanks, Owen, Five Islands School, St. Mary's.
