Set up issue
BH_10631359
2-Explorer
Set up issue
I installed cero by skipping licence step and when I open installed software it showing creo appears to have been installed using skip licensing option run the reconfigure utility to use active licence
2 REPLIES 2
this is correct behaviour. Please ask question.
Martin Hanák
@BH_10631359,
Observed behavior is working as expected. Since, Creo will need license information to get launched, you need to run reconfigure.exe present at location "<Creo_Install_Point>\Parametric\bin" and provide license information to it if you have any.
Browse to the license file if you have node locked license or provide information as "7788@<ServerName>" if you have existing license server.
