Set up issue
BH_10631359
Set up issue
I installed cero by skipping licence step and when I open installed software it showing creo appears to have been installed using skip licensing option run the reconfigure utility to use active licence
this is correct behaviour. Please ask question.
Martin Hanák
rghadge
(To:MartinHanak)
@BH_10631359,
Observed behavior is working as expected. Since, Creo will need license information to get launched, you need to run reconfigure.exe present at location "<Creo_Install_Point>\Parametric\bin" and provide license information to it if you have any.
Browse to the license file if you have node locked license or provide information as "7788@<ServerName>" if you have existing license server.
