I have no idea how to set up license for student addition. There was a page that had installation instructions but as I moved forward to the installation I lost that page. What do I use for the license file?
"PTC Creo 9.0 - Student Edition": https://apps.ptc.com/schools/references/install_creo9_unistudent_standard.pdf
"PTC Creo 10.0 - Student Edition": https://apps.ptc.com/schools/references/install_creo10_unistudent_standard.pdf
Hi @CA_11067387,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
