Student Edition Licensing Problem
flix
I appear to be experiencing a licensing problem when I want to make a welding in the welding application. I am using Creo Elements/ Pro 5.0 Student Edition and can run the welding application without problems. But when I actually want to place a fillet weld, Creo tells me that a file called iso_fillet.sym located in Program Files\Creo Elements\Student Edition\symbols\library_syms\weldsymlib\iso_weld is created with a commercial license of Creo and therefore not compatible with my Student Edition. Then, Creo crashes. Does anyone experience a similar problem? Or even know a solution?
Cheers and Thanks, Felix
3 REPLIES 3
VladimirN
(To:flix)
Hello!
The list of available modules for version Creo Elements/Pro Schools Edition can be found here: http://www.ptc.com/appserver/wcms/standards/textoimgothumb.jsp?&im_dbkey=36262&icg_dbkey=841
And If you have any questions send an email to -
flix
(To:VladimirN)
Thanks Vladimir, I'll ask the folks at ptc about it!
VladimirN
(To:flix)
No problem.
