Simulate and simulate lite apparently do NOT load automatically with the student license... but they ARE available. I had to re-run the installation and then EXPAND a box next to "Creo" (as I recall) to see a list of subcomponents that would and would not be loaded. The simulate option was NOT checked. Once I checked it and finished that process it became available as a tab in Creo.
@ptc-4266881 wrote:
Your website says the student edition comes with simulate-lite... but it does not. It is not listed when I go to >help> system information even though I very explicitely checked the box to install "simulate" during the installation process. What's up? How do we ACTUALLY get simulate-lite to work?
@ptc-4266881 wrote:
It opens, but all menus are grey. More importantly, going to >file>help>system information lists mechanisms and lots of other packages but does not show simulate.
1.] I think Simulate Lite module is not present in System information window, because it does not have any code assigned. It is free.
2.] What Creo version do you use ?
3.] Attach picture of Creo window before and after clicking Simulate button.
@ptc-4266881 wrote:
All of the modules that are listed are free. Simulate would definitely be listed if it was present.
FYI ...
1.] Creo Student license can be used free of charge by students, only
2.] Lite modules are available for free for all Creo users, these modules have limited functionality
video simulate_lite.mp4 shows how to access Simulate Lite mode. Please note that Simulate Lite has special UI that differs from standard Simulate UI (which is greyed).
