Hey everyone,
I have a problem, when I try to activate my student license for Creo 7.
The setup finds the student license but says the licensing file is invalid. Any ideas?
Update:
I got the License to work, but still have a Problem.
Now it says: License request failed for feature Invalid feature name: [Feature_Name]
I tried solutions from other posts (editing the startup file) but it does not work.
@EH_10076300 wrote:
Thank you very much!
It seems to have worked, but now it says that my feature has expired.
Any Ideas for that? It also tells me it could not find the AFX and IFX.
Eike
feature has expired means that your license does not work anymore. PTC generates license valid for 1 year only - look into license file, you will find end date of your license in it.
You must:
You can also ask to send new license via email - see my previous reply.
@EH_10076300 wrote:
Hey everyone,
I guess your license file is empty, this means it is invalid.
Please contact academicsupport@ptc.com. You need to send them the Host ID (Mac address of the ethernet) and also the product code used. I hope they will send you valid license file.
Hi, Thank you!
Do you also have an Idea for my second Problem?
Eike
if you have valid license file then:
1.] open valid license file in Notepad
2.] go to Creo installation into Parametric\bin sub directory and open parametric.psf in Notepad
3.] modify parametric.psf
ENV=PTC_D_LICENSE_FILE-=here_put_full_path_to_license_file
ENV=CREOPMA_FEATURE_NAME=CREOPMA_xxx ()
CREOPMA_xxx ... look into your license file ... here you will find the real license name starting with CREOPMA_
4.] save parametric.psf
5.] start Creo
Eike
Eike
You must:
