Hi. I have a problem with the license identification: Student code give me an error message.
Thanks for the attention.
you can request license file via email. Please read https://community.ptc.com/t5/PTC-Education-Forum/Creo-Parametric-9-0-Student-Edition-Licence-error/m-p/897846 discussion.
Which version of Creo do you want to install?
Version 11
Yes, but the license code doesn't work.
Thank you. I've received an other email form the Academic Support with an other license, but it still doesn't work.
please publish some valid information. For example picture showing error message.
You can also upload following files:
Hi. This is the error I obtained with the license I received by email from Academic Support. I've also attached the ip.txt as you suggest.
Thank you
Hi.
Could you please tell me where I can found the Parametric\bin\parametric.psf file? I cannot upload the license file since I receive this error message
if you have problems to upload the file, pack it into zip file and upload zip file.
Example ... E:\PTC\Creo11_020\Creo 11.0.2.0\Parametric\bin\parametric.psf
