Student edition - License invalid file or format
leondorofeev
2-Explorer
I tried to install Creo 5 Student edition and I get a invalid file or format error.
Attached is the output of ipconfig because I saw that some people have the same problem.
Thanks for your feedback, Leon
7 REPLIES 7
I can't see anything wrong in ip.txt file. Maybe removing home from Verbindungsspezifisches DNS-Suffix in network card settings will help.
Please upload licence file located in C:\ProgramData\PTC\Licensing directory.
What Product code did you enter during installation ?
Martin Hanák
Hello Martin,
thanks for your fast reply!
removing the DNS suffix is not working
I use license code BK500806ED0790-Y3M9-4RW5
License file is empty
Any more idea?
Thanks and bye, Léon
Hello Martin,
Any more idea?
tip no.1]
Move all files from C:\ProgramData\PTC\Licensing directory "somewhere else"
Uninstall Creo 5.0
Install Creo 5.0 and use Product code BE500806EDSTUDENTEDK12
tip no.2]
Download Creo 6.0 installation media + unzip it
Uninstall Creo 5.0
Install Creo 6.0 and use Product code BK600908EDSTUDENTEDUNI
Install Creo 5.0 ... do not enter Product code ... in Source field enter path to Creo 6.0 license file located in C:\ProgramData\PTC\Licensing directory
tip no.3]
Email your request to academicsupport@ptc.com and to akarim@ptc.com (Abdulkarim, Abdul).
Explain them that you need BK500806ED0790-Y3M9-4RW5 license or BK600908EDSTUDENTEDUNI license for MAC address 50-E5-49-53-1A-B2
Martin Hanák
creo 6
I moved the program data file to somewhere else
and the i rentered the product code from the guide but it still shows invalid file or format
and i have not received mail
@ND_9785545 wrote:
creo 6
Explain them that you need license (enter Product code) for MAC address (enter your MAC address).
Martin Hanák
Possible solutions for "Invalid file or format" status under License Summary while installing Creo: https://www.ptc.com/en/support/creo-admin-troubleshooter/other-symptoms/invalid-file-format
AK
2-Explorer
2-Explorer
(To:leondorofeev)
Same problem here.. what should  i do?.. please tell me step by step procedure.. i dont have PTC  FILE  in C drive... please reply as soon as possible. 🙏🙏
