Hey, I've got the same problem, but could not fix it with the instructions above. Could someone please help me out? I've already tried changing my password and followed the relicense guide. I recieved a document saying that my license is renewed (see attachments), but creo still says that my license expires in 14 days.
My Host-ID is E0-0A-F6-5E-38-C5.
Thank you very much.
RE: post
Example:
RE: post
1.]
New license file you received via email contains license valid up to 24-Feb-2024. Inside the file there is license code which enables you to run Creo up to version 8.0. You can run 6.0, too!
2.]
To "connect" new license file to existing Creo 6.0 installation, please follow this procedure:
Hi Martin,
thank you very much for your answer. I want to refresh my license for my existing Creo 8.0.4.0 installation, does your instruction work the same for this version? I could not find any Parametric\bin sub-directory...
Best regards
Jakob Spreng
Example:
Hi Martin, thank you very much for your respond. Creo works again without asking for any license renewals.
