Hello , i have a commercial version of Creo on my laptop, if i down loaded student version so i can help out the students on the FRC team will effect my commercial version of creo
Hi, you don't even need to download or install the software. Just install the license and then you can choose between COMM and EDU at startup.
On a similar theme is there a way of simply roling back from EDU -> School -> Student depending on what licence server the system can see?
Regards
